Problem with subforms and moving databases
Hello!,
I have a webapplication with a set design for this design i use a number of subform like 1 for the top logoheader 1 for a menu row 1 for a menu to the right 1 for the footer and so. These subforms I have in a database called settings (where the menu items and all that also are stoed). I also have a few databases that needs to use the same design. So when insterting a subform in the new databases I just choose the subform from settings that way if I change in settings the design will change in all databases. this works nicely.
Though the database must be copied now (and in the future atleast 1 more time when we install it to the customer) and when I copy all databasdes to a new catalog the subforms in the copied databases still links to the original settings not the copy. and deleting and replaysing all the subforms in all databases will take too much time … and I cannot use a document with the server/database since computed subforms isnt able to get a subform from another database.
Anyone have any tip on how to solve this? or is the timeconsuming way the only way?
