Subject: RE: Problem with starting servlet manager
Ok, i restarted the server with three different options as Servlet Manager:
None, Domino Servlet Manager and Three Party.
And when restarting the server, the log entries are always the same.
Here the log (anonymised):
Lotus Domino (r) Server, Release 6.0.2CF1, June 9, 2003
Copyright (c) IBM Corporation 1987, 2003. All Rights Reserved.
15.12.2003 09:35:20 Event Monitor started
15.12.2003 09:35:20 Begin scan of databases to be consistency checked
15.12.2003 09:35:20 End scan of databases: 29 found
15.12.2003 09:35:21 Server started on physical node xxxxxxxx
15.12.2003 09:35:22 The Console file is D:\Lotus\Domino\Data\IBM_TECHNICAL_SUPPORT\console.log
15.12.2003 09:35:22 Console Logging is DISABLED
15.12.2003 09:35:22 Database Replicator started
15.12.2003 09:35:22 Replicator is set to Ignore Database Quotas
15.12.2003 09:35:22 Admin Process: xxxxxxxx/xxxxxxxxxxxxx/AT is the Administration Server of the Domino Directory.
15.12.2003 09:35:22 Calendar Connector started
15.12.2003 09:35:22 Starting update of database usage statistics
15.12.2003 09:35:23 Schedule Manager started
15.12.2003 09:35:23 Index update process started
15.12.2003 09:35:23 LDAP Server: Starting…
15.12.2003 09:35:23 Administration Process started
15.12.2003 09:35:23 LDAP Server: Serving directory names.nsf in the xxxx Internet domain
15.12.2003 09:35:23 LDAP Schema: Started loading…
15.12.2003 09:35:23 Mail Router started for domain xxxxxxxxxxxxx
15.12.2003 09:35:23 Router: Internet SMTP host xxxxxxxx in domain xxxx
15.12.2003 09:35:24 Database Server started
15.12.2003 09:35:24 Agent Manager started
15.12.2003 09:35:24 HTTP Server: Using Web Configuration View
15.12.2003 09:35:25 IMAP Server: Starting…
15.12.2003 09:35:25 POP3 Server: Starting…
15.12.2003 09:35:25 SMTP Server: Starting…
15.12.2003 09:35:25 Schedule Manager: Informational: Detailed schedule information collection is not enabled via the domain-wide S
erver Configuration document.
15.12.2003 09:35:25 SchedMgr: Validating Schedule Database
15.12.2003 09:35:25 AMgr: Executive ‘1’ started
15.12.2003 09:35:26 LDAP Schema: Finished loading
15.12.2003 09:35:26 JVM: Java Virtual Machine initialized.
15.12.2003 09:35:26 HTTP Server: Java Virtual Machine loaded
15.12.2003 09:35:26 IMAP Server: Started
15.12.2003 09:35:26 SchedMgr: Done validating Schedule Database
15.12.2003 09:35:26 POP3 Server: Started
15.12.2003 09:35:26 SMTP Server: Started
15.12.2003 09:35:27 LDAP Server: Started
15.12.2003 09:35:27 DIIOP Server: Starting…
15.12.2003 09:35:27 DIIOP Server: Unable to obtain the server’s IP address, will use loopback address: No address associated with
name
15.12.2003 09:35:28 DIIOP Server: Started
15.12.2003 09:35:29 HTTP Server: Started
15.12.2003 09:35:32 Finished updating usage statistics
Thanks for your help.
Markus Ströbel
