Problem With SMTP and IMAP
Hi all,
Recently I configure the IMAP service in my Domino Server.
I conect without problens using the Mozilla Thunderbird. Every messages, folders and subfolders appeared ok.
But, when I try to send a message, I received this message: "Your Domain does not have access to route messages to the specified domain.¨
I try to send a mail to my Gmail address and to a internal e-mail too. Both give me this error.
I configure the SMTP server correctly too, I put the SMTP address and it seems ok.
Somebody can help me?
Subject: Problem With SMTP and IMAP
I am guessing that your IP Address isn’t allowed to route mail. I would check your Messaging Configuration Document - Outbound Controls, to confirm that your IP Address is allowed to route mail.
If it isn’t listed in the field, add it, then restart the Router task.
HTH.
Gregg
Subject: RE: Problem With SMTP and IMAP
Hi Gregg,
In my Domino Configuration Settings > Router/SMTP > Restrictions and Controls > SMTP Outbound Controls, all fields are blank.
Where I have to put the address? And this address is my Server IP address or my network address?
Thank you so much.
Sorry, wrong tab. Add your IP Address (not the server’s) to the field “Exclude these connecting hosts from anti-relay checks” on the SMTP Inbound Controls tab. When using IP Addresses, the numbers have to be in brackets, like this:
[xxx.xxx.xxx.xxx]
Restart the Router and test.
HTH.
Gregg
Hi Gredd,
I put my IP address in the field like this [172.16..] and I restarted the router (tell router kit, load router). But now I received a new error message:
Server Responce: [TRYCREATE]: Mailbox does not exist.
The Server send the message even with the error above. But return the same error message before: “Your Domain does not have access to route messages to the specified domain.”
Thanks for the help.
