Hi All
I am in the middle of developing a web application. My requirement is as given below.
I have a form that has some fields. The mail field is called employee name. When I enter the employee name and click submit, other fields should be filled in based upon the name given.
I am trying to get the data using an agent. I am giving the code I have written below
On ClicK
window.open(“http://”+loc+“/EmployeeDetails.nsf/Getvalue?OpenAgent”)
GetValue agent
Sub Initialize
On Error Goto errHandler
Dim doc As notesdocument
Dim newdoc As NotesDocument
Dim db As notesdatabase
Dim view As NotesView
Dim item As notesitem
Dim thisDoc As notesdocument
Dim ID As String
Set db=session.GetDatabase("","employeedata.nsf")
Set doc=session.DocumentContext
Set view=db.GetView("PeopleData")
nam$=doc.EmployeeName
Set newdoc=view.GetDocumentByKey(nam$)
If Not newdoc Is Nothing Then
email=newdoc.InternetAddress(0)
thisDoc.BussEmail=email
Else
Print "No Document Found"
Getvalue="Nothing"
Call doc.save(True,True)
Print "<SCRIPT LANGUAGE=JavaScript>"
Print "window.open('/" & parse_path(db.FilePath) & doc.UniversalID & "?EditDocument','_self')"
Print "</SCRIPT>"
errHandler:
Msgbox "Initialize Function in Agent Getvalue Error on line " + Cstr(Erl()) + " - "+Error$
Resume Next
Function parse_path(orig_param As String)
Dim char As String
Dim retval As String
Dim i As Integer
retval = ""
For i = 1 To Len(orig_param)
char = Mid$(orig_param, i, 1)
If char = "\" Then
char = "/"
retval = retval & char
Next i
parse_path = retval
End Function
Whenever i try this I am getting a blank page.
Can anybody please help?
Thanks In advance
Ranjith
