Problem with session.CommonuserName
Hello, We recently upgraded our Notes/Domino environment from R5 to R7 since doing so, I encountered this issue with one of my databases.
I have the following code in the Terminate Event of the “Author” field to capture the field editor’s name, date & time. The field stop working for users that have R7 client.
Any feedback on this would be greatly appreciated.
Sub Terminate
Dim uidoc As NotesUIDocument
Set uidoc = workspace.CurrentDocument
Author = uidoc.FieldGetText (“Author”)
RevApproval_a = uidoc.FieldGetText (“RevApproval”)
If Author = “” Then
If RevApproval_a <> “” Then
Author = "Completed by " & session.CommonUserName & " on " & Format(Now(), “Long Date”)
Call uidoc.FieldSetText (“Author”, Author)
Call uidoc.save
Thanks in advane for your help!
Regards
-tb
Subject: problem with session.CommonuserName
You might be better off moving this code to the ‘QuerySave’ event of the form (you would need to remove the ‘Call uidoc.Save’ code).
Subject: RE: problem with session.CommonuserName
Thanks, Alex! When I placed the code in the ‘QuerySave’ event, I’m get ‘Variant doesn’t contain an object’ error and the validators name doesn’t append in the field. Any other suggestion?
Thanks Again!
tb
Try this code in the QuerySave event of the form:
Dim Session As New NotesSession
Dim Doc As NotesDocument
Set Doc = Source.Document
Author = Doc.Author(0)
RevApproval_a = Doc.RevApproval(0)
If Author = "" Then
	If RevApproval_a <> "" Then
		Author = "Completed by " & Session.CommonUserName & " on " & Format(Now, "Long Date")
		Call Doc.ReplaceItemValue("Author", Author)
Thanks, Alex! I placed your code in the QuerySave section and the field now shows the right user name. Since this is a workflow database, I have other three approval sections with the below code. The code executes when users click on action buttons to approve/deny a request.
How would I be able to incorporate the below code in the QuerySave event?
When supervisors approve a request, the request would be routed to a Manager. The manager section has two fields (MgrApproval & MgrAuthor). MgrApproval has a drop-down list of “Approved” & “Denied”. Inside the ‘MgrAuthor’ Terminate event, i have the below code to capture the Manager’s name when he/she approve/deny a request…
Sub Terminate
MgrAuthor = uidoc.FieldGetText("MgrAuthor")
MgrApproval_a = uidoc.FieldGetText ("MgrApproval")
If MgrAuthor = "" Then
	If MgrApproval_a <> "" Then
		MgrAuthor = "Completed by " & session.CommonUserName & " on " & Format(Now(), "Long Date")
		Call uidoc.FieldSetText("MgrAuthor", MgrAuthor)
		Call uidoc.save
Director section have the below code…
Sub Terminate
DirectorAuthor = uidoc.FieldGetText("DirectorAuthor")
DirectorApproval_a = uidoc.FieldGetText ("DirectorApproval")
If DirectorAuthor = "" Then
	If DirectorApproval_a <> "" Then
		DirectorAuthor = "Completed by " & session.CommonUserName & " on " & Format(Now(), "Long Date")
		Call uidoc.FieldSetText("DirectorAuthor", DirectorAuthor)
		Call uidoc.save
Thanks in advance for your help!
The logic in the other sections is the same as that for the sample code I gave you. Shouldn’t be hard to use the example I gave and add more code and simply the replace the Author and RevApprover with the field names for your other sections.
Thanks a lot, Alex! I did that and everything works fine now. I appreciate your patience!
tb
