Problem with searching words
Hi!
I have a problem with searching Lotus Notes mails with specific word.
I made very simple condition in Search view: just give me all mails with word ‘software’? I didn’t change default settings i.e. I didn’t click to ‘More’ and change anything (btw settings are to use word variant and to sort results by relevance). The thing is that I noticed that even if some mails older than 3 months or later in Inbox contains that word, they were not selected? I just don’t get how this search engine works, does date has influence in getting right results?
Thanks in advance…any help is welcomed.
Sanela
Subject: Problem with searching words
is your mail file full text indexed? if it is try to delete and recreate it
Tim
Subject: RE: Problem with searching words
Tim, thank you very much! It helped!! :slight_smile:
Load compact -D mail\xxxx.nsf
I have seen that databases are full indexed and I didn’t think I should index them again, but I guess something went wrong during immediate indexing.
Thanks again!
Regards,
Sanela
