First of all, let me say Woo Hoo! Great job with DDE.
However, not unexpectedly there are a few issues
Problem 1
Lotuscript Libraries with a period in the name are truncated or blank in the DDE listing of design elements.
If I edit the library name, it shows up OK (I have edited the name of .AppArchive , added .Test and copied & renamed Test.Test - these are all OK), but unaltered names do not show up.
Simply opening, saving and closing the script library is does not fix the issue
The empty lines in this screen-shot are libraries which start with a period
And this shows a group of libaries which all start with the same thing, but have different endings
I notice that when I first open one of these script libraries, the name shows like this
After I change the name at the ‘view’ level, I get this
- note that “.lss” has been added on to the end
Problem 2
The sort order in the Database Navigator view? (panel? pane? window? - what is the new terminology?) is different to the detailed design element listing - I suppose this may be related to problem No 1.
Problem 3
The properties pane at the bottom does not include the script library name or language, and is labelled ‘Activity’. Why Activity? The heading is missing for Design, but says Fields and IDs for the last two tabs
Question 1
Is the ‘In View Edit’ the only way to change the script library name now that the properties view has replaced the old-style info box?
