Problem with schedule agent
hi,when i try to make any schedule agent i got this message …“YOU DO NOT HAVE EXECUTION ACCESS PRIVILEGS FOR AGENT ‘’ on ‘’; IT WILL NOT RUN”
i know this problem will solve by lotus administrator but i want to know this
please help me…
thanks
sashi
Subject: problem with schedule agent
Your name ( rather the agent signer’s name ) has to be listed in the Server document to run agents.Open the server document > Security tab and look into the section heading “Programmability Restrictions”. You have 2 field i.e. “Run restricted LotusScript/Java agents” & “Run Simple and Formula agents” where the name has to be listed.
cheers !!
Ashish
in the server’s security settings the Administrators specify which users may sign and run agents on that server. Your user id is simply not listed there.
When the administrator fixes this agent problem for you, he basically signs your agent with a user id (possibly his own admin id, or a server id, or a certain trusted id) that has the privilege to run agents on the server.
Best regards
Mario Varchmin
http://www.e-llennium.com/e-llennium/index_en.htm
