Problem with saving new document on web
When I save a new document on the web, instead of redirecting to the newly saved document (with seq=n), I get a “page not found” instead. It also ignores my $$Return field. If save an existing document, there is no problem at all.
I am using a formula submit button (FileSave/FileCloseWindow) and the “use Javascript when generating pages” option. There is no web query save agent specified and nothing in the server logs. I don’t remember ever having this problem before. Any ideas? Thanks.
Subject: Problem with saving new document on web
Using @Command([FileSave]) AND @Command([FileCloseWindow]) should not take you to the same document, but should really close it. If there is no $$Return item, I would expect it to show Form processed, though.
(Edit: No, that’s what takes you to the database start page.)
If you want to keep editing the same doc (with appended/updated Seq no), simply omit the second @Command.
Subject: RE: Problem with saving new document on web
Okay, that makes more sense.
I found that I get the 404 error if I specify a relative URL in $$Return. An absolute URL or plain text works fine. I didn’t realise this limitation existed.
I actually expected to see “Form processed” initially. When does this message occur?
Relative URLs are just fine in $$Return, but watch out where a relative link takes you.
Problem is (most of the time), that the virtual directory structure for opening a document is one level deeper that for opening a form (because of the view). I prefer to make all my links relative to the host name like
"[/ + @WebDbName + “/MyForm?OpenForm]”
"[/ + @WebDbName + “/MyView?OpenView]”
"[/ + @WebDbName + “/0/” + @Text(@DocumentUniqueId) + “?EditDocument]”
What’s the address of that “page not found”.- maybe a formula-error in the $$Return ?
The URL on the 404 is “http://my-server/my-db.nsf/my-form?OpenForm&Seq=1”. Looks ok.
However, if I leave the $$Return field blank, on save the window redirects to the database home. eg. http://my-server/my-db.nsf.
Not sure what the problem is. My $$Return value is just a straight URL string surrounded with square brackets.
Are you trying to have it return to the same document, opened and in read mode? Or to an appropriate view w/ it highlighted?
“Or to an appropriate view w/ it highlighted?” - Is there a Domino feature that does this automatically? Or do you need to write the URL yourself (eg. view query)?
Yes, you have to create an appropriate view URL command yourself. No one-click feature, but not hard to do.
