Problem with rules
hello
I disable a rule in my mail but it is still running on the server
So I deleted the rule but it is always the same
Have you a solution to see ghosts rules on Notes clients or view all the rules of Lotus customers on the server
Thank you for your return
Olivier Picard
Subject: to refresh the rule
The server may take some to refresh it. You may try to create a dummy rule, then delete it to refresh the rule.
Subject: forwarded to development <eom.
mh/sjc
Subject: This is probably an old issue…
Search the Notes 6 forum for more info, but this is probably another old issue that’s never been resolved.
This is a button agent I send to users with this issue, it removes all the rules.
Sub Click(Source As Button)
Dim db As NotesDatabase
Set db = session.currentdatabase
'This folder contains all the Mail Rules.
Dim folder As NotesView
Set folder = db.GetView("(Rules)")
'Find the calendar profile document in the current database. (GetProfileDocument will create the named profile document if it does not already exist.)
Dim calendarProfile As NotesDocument
Set calendarProfile = db.GetProfileDocument( "CalendarProfile" )
'Mail Rules are compiled and saved in special fields named $FilterFormula_xx
'Remove all of these fields from the calendar profile.
Forall item In calendarProfile.Items
	If( Lcase$(Left$(item.Name,15)) = "$filterformula_" ) Then
		Print "Cleanup " & item.Name
		Call item.Remove
End Forall
'Save changes to the calendar profile.
Call calendarProfile.Save( False, False )
'Disable all Rules.
Dim mailrule As NotesDocument
Set mailrule = folder.GetFirstDocument
While Not( mailrule Is Nothing )
	Call mailrule.ReplaceItemValue( "Enable","0" )
	Call mailrule.Save( True,False,True )
	Set mailrule = folder.GetNextDocument( mailrule )
Wend
'Open the Rules folder
Call workspace.OpenDatabase( db.Server, db.FilePath, "(Rules)" )
'Message to the user.
Messagebox "Cleanup complete."
Subject: Thanks
Thank you for the code, everything is ok now
Olivier PICARD
