Hi all,
i have the following problem:
On a form i have two text fields and one richtext field.
These three fields are merged to one Body field for an email (I cannot use one field, because the content in the richtext field is copied to another rtf in another document for history, the other fields are not relevant for history).
If the users writing text in the rtf and presses enter for a line break and send the email, the text is indented after the first line break, when the email is opened through Not-Notes clients or Webmailer. In the Notes Client it looks fine.
If i look in the html code in a Webmailer, i see that every indented line contains several “&.#160;” (w/o point after &) before the text starts.
If the user are pressing shift + enter for creating a line break, the text is not indented. I’m wondering about that, because if i create a ‘normal’ Memo in Notes with line breaks which created through enter-key and send it to the internet, the mail looks fine.
Here’s my code which creates the body field:
Dim memo As NotesDocument
Dim body As NotesRichTextItem
Dim memoBody As NotesRichTextItem
Dim rtnav As NotesRichTextNavigator
Set memo = New NotesDocument(db)
Set body = uidoc.Document.GetFirstItem(“RichTextField”)
Set memoBody = body.CopyItemToDocument( memo, “Body” )
Set rtNav = memoBody.CreateNavigator
rtnav.FindFirstElement(RTELEM_TYPE_TEXTPARAGRAPH)
Call memoBody.BeginInsert(rtnav, False)
Call memoBody.AppendText(uiDoc.Document.GetItemValue(“FirstTextField”)(0))
Call memoBody.AddNewline(1)
Call memoBody.EndInsert
Call memoBody.AppendText(uiDoc.Document.GetItemValue(“SecondTextField”)(0))
Hope someone can help me!
Thx in advance, Niki
