Problem with Rooms and Resource Database
Im getting this “No Scheduling information for the requested invitees could be found at this time” error when trying to create New Reservation, I checked out with various dates, still im getting this problem. Once after passing these values,
Reserve a Room
For whom is this reservation : Name of the business
How would you like to search : Find an a available time for a specific room
Select Room : Room 01/Location
Here is the problem, Once after clicking on Go, it display a Free Time dialog box soon the above said error message pop ups.
Recently i have created “New Resource” and re created busytime.nsf.
Any suggestions will help me a lot.
TIA… Gov G
Subject: Problem with Rooms and Resource Database
Hi Nihao,
thank you so much, tried recreating the same twice and it started working, thank you so much.
I just found this problem like you and just solved by myself may be my solution will help you sometime.
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/8f6da038600a2d23852573a20029135d?OpenDocument
Subject: RE: Problem with Rooms and Resource Database
Hi Nihao,Still im facing the same problem,
and do i need to recreate busytime.nsf once after recreating??
TIA…Gov G
