Problem with RichText-Fields
Hello,i have a problem with rich text fields.
I have a form where the rich text field is located inside a table and this field should take the value from another rich text item located in the document i created the new one on. But it seems that the rich text field in the table is not able to take the correct left margin values from the other field.
I tried this several times and found out that rich text items in tables will never take the margins from another rich text field but i have to put the field inside of a table so i would like to know if there is some way in wich the margins could be transfered correctly.
Thanks for any comments Tobias
