Hi folks,
Having a bit of trouble with the Rich Text Lite field.
I have two identical documents using the same form. When viewing the documents in a web browser (IE), one doc displays the text in the rich text lite field properly, one doc does not display the text at all.
There is no hide-when formula associated with the field.
The rich text lite field works fine in the Notes Client.
I’ve even switched the display to Java applet, and then the text disappears completely on both docs over the web. (NOTE: I don’t want to display this with a Java applet, just simple HTML. I just ran this as a test).
Has anybody run into this problem? I’m baffled! Any help would be greatly appreciated.
Thanks,
Chuck
