Problem with $$ReturnAuthorizationFailure
We’ve recently put a $$ReturnAuthorizationFailure form in one of our databases. This database is served to the web on a server (intranet) that does not allow anonymous access, so everyone is authenticated. No matter how we configure the ACL or the form, it does not come up. Instead, if users aren’t authorized, they get the login form with the system error message. They don’t even get the global authorization failure form.
The server is configured for multi-server SSO, with a custom login form. The ACL is set for both -Default- and Anonymous to have at least Reader access with Read/Write Public Documents.
The form is named correctly, and I’ve called the system message field both MessageString and $$ReturnAuthorizationFailure.
Any ideas?
Subject: Problem with $$ReturnAuthorizationFailure
Resolved, this is a known bug - NBRR628Q6V. This special form will not work in environments with any kind of session-based authentication. Even the default Global ones designated in domcfg.nsf will not work - you will only see the login form for this type of error. $$ReturnGeneralError does work, however.
