Problem with resource reservations database
I’m having some problems with the resource reservations database.
I’ve created as explained in the help file, create some sites and resources.
When I now want to find a room at a specific time, I get the following message:
No resource/room found for time and/or capacity requirement.
When I check busytime the entries are not in.
Also entries are not found in NAB (so when I want to schedule room using my own calendar it will not be found)
When I check admin request database, I see the following error on add resource
Title: Administration Requests (6) File name: admin4.nsf; Error: Document is not signed.
Does any one what I do wrong or how I can add room / resources to busytime and the addressbook…
Many thanks
Rgds,
Rudy
