Hi everyone,I run agents to replicate documents from dev03 to dev02.
The coding is not working below. The profile setting up is fine. The interval=0(just for today).
Replication formula for database on destination server is
rep:=@If(Form=“ReclassDisclosureItem”;@If(PublicDoc=“Y”;“Y”;“”;“Y”);
SELECT rep=“Y”
I thank you for your help!
Linda
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim replicadb As NotesDatabase
Dim profileview As NotesView
Dim profiledoc As NotesDocument
Dim dt As NotesDateTime
Dim currdt As NotesDateTime
Set currdt =New NotesDateTime(Today)
Set db=s.currentdatabase
'GET THE PROFILE ELEMENTS
Set Profileview=db.GetView(“vwConfigView”)
Set profiledoc=profileview.GetFirstDocument
If profiledoc Is Nothing Then
Msgbox “The application profile cannot be found. Replication cancelled.”,0+16,“Configuration Error”
Exit Sub
lastrep=profiledoc.LastReplication(0)
repinterval=profiledoc.ReplicationInterval(0)
repserver=profiledoc.ReplicationServer(0)
'DETERMINE IF THE LAST REPLICATION INTERVAL HAS PASSED.
'IF NOT, DISPLAY MESSAGE TO USER & EXIT
If Cstr(lastrep)=“” Then Goto StartReplication
If Cstr(repinterval)=“” Then Goto StartReplication
Set dt=New NotesDateTime(lastrep)
dt.AdjustDay(repinterval)
If dt.lslocaltime>Today Then
Msgbox "The specified time frame has not passed until replication can occur again. Please wait until " & dt.localtime & “, and try again.”,0+16,“Replication Error”
Exit Sub
'VERIFY A REPLICA EXISTS ON THE SERVER TO REPLICATE WITH
Set replicadb = New NotesDatabase( “”, “” )
If Not(replicadb.OpenByReplicaID( repserver, db.ReplicaId )) Then
Msgbox “A replica of this database does not exist on “& repserver &”. Please adjust the profile document”,0+16,“Configuration Error”
Exit Sub
StartReplication:
profiledoc.LastReplication=Today
profiledoc.Save True, False
Dim agent As NotesAgent
Set agent = db.GetAgent(“(ReplicateDatabase)”)
If agent.RunOnServer = 0 Then
currdt.AdjustDay(repinterval)
Msgbox "Replication was completed successfull with " & repserver & ". You will be able to replicate again on " & currdt.localtime,0+64,“Replcation Completed”
Else
Msgbox “An error occured duriing replication. Please check the notes log.”,0+16,“Replication Error”
Here is the “ReplicateDatabase” agent below
Sub Initialize
Dim notesrep As NotesReplication
Set notesrep=db.ReplicationInfo
notesrep.Disabled=False
notesrep.Save
db.Replicate(repserver)
notesrep.Disabled=True
notesrep.Save
