I am pasting a data in richtext lite field. The script is composing a mail document and the current document is rendered to richtext item in the body field on newly composed memo. When user receives the mail the header part of the pasted data and trailer part ramins intact in the mail however the mid portion of the pasted data is getting truncated.
Subject: Problem with Renderto rtitem
I have used this technics several times and never had this problem.
Check if it still truncates the data when you switch your field to a true full RTF field rather than a RTF lite field
Check if you have an email settings that truncates emails when they are over a certain limit (like over 40K)
Check if your email is replicating (for instance locally) since there is an replication option to truncate documents larger than so many K when replicating
Check that your target email box has the option “Autorise the use of embedded forms” - I don’t think it applies in this case but it might be something to verify.
