I have some code that copies documents into a folder. Before doing this, the code needs to make sure all previously copied documents are removed. I simply do this with the lines:
Set vc = ReportFolder.AllEntries
Call vc.RemoveAll(True)
This works great most of the time. It does not work if the documents are categorized in the folder in such a way that a document appears in more than one category. Does anyone know how I can clear out documents in a different way that will work all the time?
If you have records which shows in multiple times then you may have to use a little different approach in deleting all. It’s little tricky. I hope the following code will work for you.
Sub Click(Source As Button)
Dim db As NotesDatabase
Dim view As NotesView
Set view = db.GetView("TEMPFOLDER")
Dim doccoll As NotesDocumentCollection
Dim entrycoll As NotesViewEntryCollection
' The following lines of code is to remove documents permanently from the folder
For index = 33 To 126
key = Chr(index)
Set doccoll = view.GetAllDocumentsByKey(key, False)
If (doccoll.Count > 0) Then
Call doccoll.RemoveAll(True)
Else
Print "No documents starting with: " + key
Next
' The following two lines of code is to remove all (Not Categorized" entries, if any
Set entrycoll = view.AllEntries
If (entrycoll.Count > 0) Then
Call entrycoll.RemoveAll(True)
I have another alternate solution for your problem. The performance you may have to test my previous one and this one and which one is better for you, you can use that.
Dim DummyView As NotesView
Call entrycoll.PutAllInFolder("DUMMY-XYZ", True)
Set DummyView = db.GetView("DUMMY-XYZ")
Set entrycoll = DummyView.AllEntries
