Problem with R6 & R5 compatibility
Hi! I developed a system using formula in R6.5.1. The testing went smooth using the same release. However, the output differs when R5 is being used. I did not used any function that is not included in R5. What would be the best solution to this problem?
Subject: Problem with R6 & R5 compatibility
Post some details! i.e. example of the formula and the output in R5 and R6.
Sometimes when there are differences in results there is a mistake in the formula and one version is more forgiving than the other.
HTH - Rufus.
Subject: RE: Problem with R6 & R5 compatibility
Hello! One of them is the inability to setfield the audit field when the user opted to write a comment. In R6, the comment is diplayed.
Written in a action button
@If(Status = “Open” & MessageWrite != “”;@SetField(“Audit”;MessageWrite + @NewLine + "*** Submitted by " + @Name([Abbreviate];@UserName) + " (Requestor) " + "on " + @Text(@Now) + “. ***”);
Status = “Open” & MessageWrite = “”;@SetField(“Audit”;"*** Submitted by " + @Name([Abbreviate];@UserName) + " (Requestor) " + "on " + @Text(@Now) + “. ***”);
Status != “Open” & MessageWrite != “” ;@SetField(“Audit”;MessageWrite + @NewLine + "*** Submitted by " + @Name([Abbreviate];@UserName) + " (Requestor) " + "on " + @Text(@Now) + “. ***” + @NewLine + Audit);
@SetField(“Audit”;"*** Submitted by " + @Name([Abbreviate];@UserName) + " (Requestor) " + "on " + @Text(@Now) + “. ***” + @NewLine + Audit));
