Hi there,
I have a Notes app that runs in a frameset using the NotesView and NotesPreview frame setup.
If I have a document in the NotesPreview frame in edit mode, and click on a different document in the view in the NotesView frame, the document that was open in the NotesPreview frame opens in a new window. Additionally, the view doesn’t change focus to the document I clicked on. I have to close the document that opened in the new window, and click on the view again to select the new document.
This doesn’t happen if the doc in the NotesPreview frame is Read mode. I have some code in Queryclose, but the behavior is the same with or without it.
Any ideas?
Thanks in advance,
Scott
