Hello,
My lotus notes does not start after installing 802 FP1 CCH2. When i try to open notes in basic mode, it opens but fails to open in standard mode. I came across the following link.
J2SE feature patch in 8.0.2 CCH2 causes failures launching Notes Standard
Configuration
http://www-01.ibm.com/support/docview.wss?uid=swg21366840
This tech note is applicable for 802 CCH2 where i am trying to install 802 FP1 CCH2 but the symptoms are similar to my case.
As described in the article, i tried to move to higher fix pack that is FP2. Still same problem is happening.
Please help.
Regards,
Bikash
