Problem with Manager & Designer
I have problem with notes security.I want to create one application where Manager & Designer should only see the document created by other but can not edit it, (documents should only be edited by person who has created it) or can not take away form this database by copy or any other method.
conditions are :
they can only read documents
documents can be edit by its creator
should not be copy to other database.
or can not do any thing by creating new form, view or agent etc.
i want to achive true security.
Subject: Problem with Manager & Designer
Managers and Designers can ALWAYS edit documents that they can see. That is the very definition of those access levels. In addition, Managers can change any ACL settings you want to put in place, and both Managers and Designers can alter any code you put in place to try to prevent any action.
