Sound like either the folder you moving the documents to is corrupted or the design for the folder is the rules folders.
Try using the Actions/Folder/Upgrade Folder Design - Choose manual then select the folder you want and upgrade its design. Make sure that you select "($Inbox) at the bottom of the Manual upgrade dialog to get the design from.
