Problem with LSXODBC Insert
I’m having trouble adding new rows to this table when there are existing rows. If I drop the entire table first I can loop through and add all records successfully, but when I condition the DELETE so there are records left in the table the agent errors out when it gets to the result.updaterow.
Has anyone else run into this problem and/or know a solution?
qry.SQL = “DELETE FROM Ticket_ARMS where Ticket_ID is not null”
result.Execute
qry.SQL = “SELECT * FROM Ticket_ARMS”
result.Execute
While Not(doc Is Nothing)
result.AddRow
Call result.SetValue(“DocID”,doc.universalid)
		Call result.SetValue("SSN",Left$(doc.SocialSecurityNumber(0),9))
		Call result.SetValue("RequestNumber",Left$(doc.RequestNumber(0),8))
		Call result.SetValue("LastName",Left$(doc.lastname(0),30))
		Call result.SetValue("FirstName",Left$(doc.firstname(0),20))
		Call result.SetValue("MiddleName",Left$(doc.middlename(0),20))
		Call result.SetValue("ManagerName",Left$(doc.managername_1(0),50))
		Call result.SetValue("NewUserID",Left$(doc.newuserid(0),20))
		Call result.SetValue("DeleteAccess",Left$(doc.deleteaccs(0),20))
		Call result.SetValue("AddAccess",Left$(doc.addaccs(0),20))
		Call result.SetValue("Transfer",Left$(doc.transfer(0),20))
		Call result.SetValue("NameChange",Left$(doc.namechange(0),20))
		Call result.SetValue("PreviousName",Left$(doc.previousname(0),20))
		Call result.SetValue("UserIDAssigned",Left$(doc.useridassigned(0),8))
		Call result.SetValue("RetailName",Left$(doc.retailname(0),50))
		Call result.SetValue("RetailBank",Left$(doc.retailbank(0),10))
		Call result.SetValue("RetailBranch",Left$(doc.retailbranch(0),10))
		Call result.SetValue("NonRetailModel",Left$(doc.nonretailmodel(0),50))
		Call result.SetValue("LotusBankNum",Left$(doc.lotusbanknum(0),10))
		Call result.SetValue("LotusBranchNum",Left$(doc.lotusbranchnum(0),10))
		Call result.SetValue("LotusExpDate",Left$(doc.lotusexpdate(0),10))
		Call result.SetValue("INotesBankNum",Left$(doc.inotesbanknum(0),10))
		Call result.SetValue("INotesBranchNum",Left$(doc.inotesbranchnum(0),10))
		Call result.SetValue("RequestType",Left$(doc.requesttype(0),50))
result.UpdateRow
Set doc = view.GetNextDocument(doc)
Wend
result.Close(DB_CLOSE)
con.Disconnect
Subject: Problem with LSXODBC Insert
Andrew
what is the error message that you are getting?
after you do the insert print the error message as in
print result.getExendedErrorMessage
This will tell you what went wrong.
john
Subject: RE: Problem with LSXODBC Insert
Sorry, I should’ve mentioned that I tried that and all I got was “LS:DO- ODBC could not complete the requested operation.”
That was the message you got when you added in the statement I asked you to put in?
Also hat are you connecting to?
I have conected to excel, access, oracle and even notes. Never had that issue, but the extendederrormessage should have told you more than that.
You may have to play with the result settings, or I think I had to do something funcky with the addRow.
John
I am connecting to a SQL Server db.
I found the problem. I added Result.NextRow immediately before Result.AddRow and that allowed me to insert after the existing rows. Thanks for responding, John.
Drew
Subject: Problem with LSXODBC Insert - Simular problem
Hi, AndrewI have a problem like you had.
Im am adding new rows to a sql-db on a Microsoft SQL-server. I am using LS ODBC-classes.
Adding new rows is no problem. Rows are built from a notes document. When I want to “export” a notes again (a row from that notes document already exists), I get the LS:DO-ODBC error: ODBC could not complete …etc.
When I manually delete that row from the sql-table, I can add a new row from that Notes document successfully.
Here is some code:
Dim (declare ODBC-variables)
qry.SQL=“SELECT * from table”
set result.query=qry
result.CacheLimit=DB_NONE
result.Execute
result.LastRow
result.AddRow
call result.SetValue()
result.UpdateRow
So, when this row already exists, the operation failes.
I hope you, or someone else, can help me.
Koos van Harmelen
When I manually delete that row from the sql-table, I can add a new row from tah Notes document successfully.
Koos van Harmelen
Glad you found it. hopefully when i said something funcy about addrow, that helped you out. now that you mention it, that is what I did also - just glad you got it solved. good luck.
Yes, your addrow suggestion jogged my memory just right. Thanks again :slight_smile:
