Problem with lotusscript code
First of all my lotusscript knowledge isn’t that good. I’m just editing an existing script
I’m having problems with a lotusscript code. This should import only a textline in a field (this is working) but it should also check if the text link already exists (I can’t get it working)
This is what I thought the script should be for checking if description already exist (It just a part of the wholde script)
If anyone could help that would be really fine.
Many thanks
Set dc = view.GetAllDocumentsByKey(Description)
Set doc = dc.GetFirstDocument
Do While Not doc Is Nothing
If (IpNumber=Description) Then
"marked for deletion
doc.DeleteRemark = “True”
Call doc.save(True,True)
Set doc = dc.getnextdocument(doc)
Else
Loop
Subject: Problem with lotusscript code
what is ‘IpNumber’ ?A string variable? A field? How is it retreived/assigned?
Same for ‘Description’?
What do you mean by ‘It doesn’t work’? Do you get an error message?
You’ll have to give more details or code to answer your question.
Subject: RE: Problem with lotusscript code
I didn’t know it it was allowed to add whole script to the website, so here it is.
I don’t get an errormessage. When I run it twice a new document with same description appears in the database.
Sub Importadresses
Dim s As New notessession
Dim db As notesdatabase
Dim view As notesview
Dim dc As notesdocumentcollection
Dim doc, NewInvoiceDoc As notesdocument
Const Formule= "@Unique"
fileNum% = Freefile()
fileName$ = "c:\tmp\upload.txt"
Print "Importing Adresses... "
Set db = s.currentdatabase
Set view = db.GetView("(Ipnumber2)")
Open fileName$ For Input As fileNum%
Do While Not Eof(fileNum%)
	Line Input #fileNum%, regel$
	If regel$="" Then Exit Do
	lengte = Len(regel$)
	pos = Instr(regel$, Chr(34))
	Description = Trim(Left(regel$, pos - 1))
	regel$ = Right(regel$, lengte - pos)
	'check if document already exists:
		If  (NewInvoiceDoc.IpNumber = Description) Then
		'mark for deletion
			doc.DeleteRemark = "True"
		Else
	Loop
    'new document
	Set NewInvoiceDoc = New NotesDocument(db)
	NewInvoiceDoc.Form = "klant"
	NewInvoiceDoc.aantal = 0
	NewInvoiceDoc.status = "e-maillist active"
	Call NewInvoiceDoc.save(True,True)
Loop
 'delete marked documents
selection$ = "Form = ""klant"" & DeleteRemark = ""True"" "
Set dc  = db.Search(selection$, Nothing, 0)
Call dc.Removeall(True)
Print "Ready Importing Adresses."
I would change this bit:
    'mark for deletion
You can’t do a comparison like the line in bold. You’re comparing the contents of a string variable (Description) with the complete contents of a NotesDocument field (NewInvoiceDoc.lpNumber). If the doc field is a single value then this will be OK:
If(NewInvoiceDoc.lpNumber(0) = Description)
This is because NotesDocument.FIELDNAME(0) will return the first value of a field as a string (NotesDocument.FIELDNAME(1) will return the second, and so on). When you assign the fields / values later on, that’s OK.
I would also change this bit (unrelated, and not a part that’s “broken” but just 'cause I’m anal) from this:
            Else
    Loop
To this:
    Loop
It just flows better, and you don’t need to repeat the GetNextDocument directive.
I think I got it almost working.Only thing is that I now get an errormessage on this line If(NewInvoiceDoc.lpNumber(0) = Description)
Object variable not set
Subject: Use the debugger!!! (WAS: Problem with lotusscript code)
Your NotesDocument probably isn’t set. Please use the debugger to confirm that, and if necessary, fix it. Then you’re set.
Subject: RE: Use the debugger!!! (WAS: Problem with lotusscript code)
(I’ve used the debugger)
Sorry but how do I set the notesdocument?
