I am encountering an error on debugging the code. It is an already done project, for which i have to add functionalities.The code is as follows…
I have typed ***** in the line giving me the error of “Type mismatch”.
Sub Postopen(Source As Notesuidocument)
Dim s As New notessession
Dim db As notesdatabase
Dim view As notesview
Dim doc As notesdocument
Dim item As notesitem
Set db = s.currentdatabase
Set view = db.getview("(autoorder)")
Set doc = view.getlastdocument
status = Source.fieldgettext("status")
If status = "Ready For Purchase by OFG" Then
Messagebox "Order Moved to Purchase, Opening the order is not possible"
continue = False
Exit Sub
If source.IsNewDoc Then
If (doc Is Nothing) Then
Call Source.fieldsettext("order_no",Cstr(BL0000))
test = doc.getitemvalue("order_no")
*****test1 = Cint(Mid(test(0),3) )+ 1*****
If (Len(test1)) = 1 Then
test1 = Mid(test(0),1,5) + Cstr(test1)
Call Source.fieldsettext("order_no",test1)
Call Source.gotofield("bregion")
Elseif (Len(test1)) =2 Then
test1 = Mid(test(0),1,4) + Cstr(test1)
Elseif (Len(test1)) =3 Then
test1 = Mid(test(0),1,3) + Cstr(test1)
Elseif (Len(test1)) =4 Then
test1 = Mid(test(0),1,2) + Cstr(test1)
Else
To avoid the error, should i be entering integer or characters into the field and the length of the entered value. Please help me…
