Hi all,
i’ve found two issues according the latest Lotus Notes 8.5 Beta version.
I’ve installed the package
1St the script postInstall.sh uses rpm -qa! This is a problem because debian normaly does not use a rpm.
2nd THIS IS MY MAIN PROBLEM.
After starting Notes I’ve got the following output and Notes stopes
2008/08/08 11:28:22.723 INFO BundleEvent STARTED ::class.method=unknown ::thread=Thread-4 ::loggername=com.ibm.rcp.lapinvoker
2008/08/08 11:28:22.742 INFO CWPIM0027I: Launching LapInvoker with isSilent=false ::class.method=com.ibm.rcp.lapinvoker.application.LapInvokerApplication.run() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
2008/08/08 11:28:22.828 INFO CWPIM0032I: Starting temp wrapper script ::class.method=com.ibm.rcp.lapinvoker.application.LapInvoker.invoke() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
2008/08/08 11:28:25.960 INFO CWPIM0033I: Temp wrapper script has ended ::class.method=com.ibm.rcp.lapinvoker.application.LapInvoker.invoke() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
/tmp/_lap19508wrapper $?=0
2008/08/08 11:28:27.968 INFO CWPIM0034I: Reading result file /tmp/_lap19510result ::class.method=com.ibm.rcp.lapinvoker.application.LapInvoker.invoke() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
2008/08/08 11:28:27.969 INFO CWPIM0036I: LapInvoker result value is 1000 ::class.method=com.ibm.rcp.lapinvoker.application.LapInvoker.invoke() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
2008/08/08 11:28:27.969 WARNING CWPIM0023W: License was not accepted ::class.method=com.ibm.rcp.lapinvoker.application.LapInvokerApplication.run() ::thread=main ::loggername=com.ibm.rcp.lapinvoker.application
2008/08/08 11:28:28.172 INFO BundleEvent STOPPED ::class.method=unknown ::thread=Thread-4 ::loggername=com.ibm.rcp.lapinvoker
