Problem with Layers
I am using layers inside the table and placing the Richtext fields in layers to print the values. If I update the Richtext field with multivalues separated by newline using lotus script, it is showing only one value in print form. Seems to be it is not adding newline to the Richtext field. If I use same Richtext field out side of layer, it is working fine with no issues. This is happening only with Notes 8.0.2 where as in Notes 6.5 working fine. Thanks in advance.
