Problem with LastModified
Hi
How I can do to check if back-end document change since front-end document is open ? I try to use LastModified but this don’t work
Subject: Problem with LastModified
What do you mean with “not work”? Can’t you set a variable/field to the content of LastModified and compare this with the backend document when saving/updating etc?
  • Johan
johan@kanngard.net
http://dev.kanngard.net
Subject: RE: Problem with LastModified
LastModified seem to return last modified date of a document only If this document is not open. If the document is open at screen and modify with back-end class, lastmodified return last modified date at moment where user open this document and not last modified date where it’s been modified with back-end
