Problem with javascript library
Hi
I want to use a nice menu in javascript for my intranet
For this, I use a javascript library as follow :
I added the library in the database javascript library
In my form i wrote (pass-thru html)
the weird thing is, when I open the form itself (ie http://server/db.nsf/name?openform) it works just fine and the menu is there
but when I open a document of this form (ie http://server/db.nsf/xxxx?opendocument) the menu doesn’t appear
i’m quite at a loss there
did I do something wrong?
could someone help me please?
Subject: Problem with javascript library
Tuan,
one idea: view the source of the document, after its loaded and see if the is being loaded
Subject: RE: Problem with javascript library
yep, it’s there all rightI tried to put it both in the head and the body and it’s all the same
it works fine on a page
it works with the form
but it doesn’t work with the documents of this form…
