hi all,
this is my first post and i hope getting your help…
my OS :
suse:/ # uname -a
Linux suse 2.6.5-7.244-s390 #1 SMP Mon Dec 12 18:32:25 UTC 2005 s390 s390 s390 GNU/Linux
Domino :
installing domino
installed on (with no problem) :
/opt/mylotus/lotus/notes/65010/zlinux
domino setup :
/opt/mylotus/lotus/notes/65010/zlinux/serversetup
problem :
JVMXM004: JVM is performing abort shutdown sequence
JVMDG217: Dump Handler is Processing a Signal - Please Wait.
./serversetup: line 125: 11632 Segmentation fault ./java -verbose -ss512k -Xoss5M -cp “jhall.jar:Notes.jar:cfgdomserver.jar” lotus.domino.setup.WizardManagerDomino $datapath $1 $2 $3 $4 $5 $6 $7 $8 $9
searching found its java problem -
tried to link to new java
suse:/ # cd /opt/lotus6510/lotus/notes/65010/zlinux/jvm/bin/exe/
#mv java java2
#ln -s /opt/ibm/java2-s390-50/jre/bin/java
starting setup again :
suse:/opt/mylotus/lotus/notes/65010/zlinux # ./serversetup
-data /opt/mylotus/notesdata
./java -ss512k -Xoss5M -cp jhall.jar:cfgdomserver.jar:Notes.jar lotus.domino.setup.WizardManagerDomino -data /opt/mylotus/notesdata
just hanging with no error code
tried to trace the problem :
I change line in server setup from :
change it to (add verbose to java ) :
./java -verbose -ss512k -Xoss5M -cp jhall.jar:cfgdomserver.jar:Notes.jar lotus.domino.setup.WizardManagerDomino -data /opt/mylotus/notesdata
alot of class load till :
class load: java/awt/LayoutManager
class load: java/util/EventListener
class load: java/awt/event/AWTEventListener
class load: java/awt/LightweightDispatcher
class load: java/awt/ComponentOrientation
class load: java/lang/UnsupportedOperationException
class load: java/awt/HeadlessException
class load: com/ibm/oti/util/Msg
class load: com/ibm/oti/util/Msg$1
class load: com/ibm/oti/vm/MsgHelp
class load: java/lang/NullPointerException
Any help appreciated
- if this is not the right forum, please refere me to domino forum…
thanks in advance
