After accesing the mail-URL from a client (http://hostname/mail/user.nsf/iNotes) and downloading the iNotes stuff, the Sync Manager is installed and starts synchronizing. AFter a while it stops with the following sync-status:
“idle: The NOTES.INI file cannot be found on the search path (PATH)”.
I have verified that the Notes.ini is on the path (the iNotes install directory is on the path) so I don’t think that is the problem actually.
Anyone recognising this?
I am running a Domino 6.01 server and Windows 2000 Pro client
