Problem with [INCLUDEDOCLINK]
I’m in need of writing code to save a new document and mail it, in a Hotspot button.
When i place the line @mailsend (with [IncludeDocLink]) immediately after @command([FileSave]), an error message stating “Special Database object cannot be loaded” shows up. But it works fine when i save the document in any other part of code and then send mail with includedoclink.
How can this be solved?
Thanks in advance
Subject: Problem with [INCLUDEDOCLINK]
I think this means you don’t have a default view assigned for this database. Choose one of your views to be the default (view properties - second tab), then try the code again.
thanks
barry
Subject: RE: Problem with [INCLUDEDOCLINK]
Thank you barryI tried your idea, it works.
thanks.
