Problem with importing a secret key
So, I created a secret key
Demonstrated removing it so I couldn’t see the encrypted sections of a document
And now the problem starts
Every time I try to import the key again, it won’t ‘stick’
I go
File-Security-User Security
(Enter password)
Notes data-documents
(Secret key is not there)
Other actions-Import secret key
(Choose key, enter key password)
(Key name is correct)
Click Accept
(Key shows in list of keys)
Click OK
Now I go
(Enter password)
Any thoughts how to get my secret key to stick?
Subject: Further tests can reproduce this 100% of the time
It’s the act of deleting the secret key that prevents you from ever adding it again!
This is pretty bad, as far as bugs go
Subject: Do you use IDVault?
If so this might help… http://www-01.ibm.com/support/docview.wss?uid=swg21611902 http://www-01.ibm.com/support/docview.wss?uid=swg21611902
