Problem with import from excel?
Hi I have fallowing problem, I use code wchih is use to import items from Excel and import work’s well. If I open view with imported documents it’s look great but if I use commant:@SetViewInfo([SetViewFilter];“2”;“Proc_wag”;1)
Iit don’t work I must first open any documents one by one and if I use this command again I see required documents. I supposed that @SetViewInfo works only with document which have UID.
Is possible to that import document that those will be see if I use @SetViewInfo and not open it before.
My import code looks like below.
Sub Click(Source As Button)
On Error Goto errmsg
Dim count As Double
Dim counter As Double
count = 0
counter = 0
Set dbCurr = session.CurrentDatabase
Dim xlFilename As Variant
xlFilename = workspace.OpenFileDialog(True, "Lista plików do wyboru", _
"Excel|*.xls", "c:")
'/xlFilename = Inputbox ( "Proszę podac ścieżkę do pliku wejsciowego excel Przykładowo c:\excel.xls", "Wybór ścieżki pliku do importu" , "" )
If xlFilename(0) = "0" Then
	Exit Sub
Dim One As String
Dim row As Integer
Dim written As Integer
'// We connect to Excel and open the file. Then start pulling over the records.
Dim Excel As Variant
Dim xlWorkbook As Variant
Dim xlSheet As Variant
Print "Connecting to Excel..."
Set Excel = CreateObject( "Excel.Application" )
Excel.Visible = False '// Don't display the Excel window
Print "Opening " & xlFilename(0) & "..."
Excel.Workbooks.Open xlFilename(0)'// Open the Excel file
Set xlWorkbook = Excel.ActiveWorkbook
Set xlSheet = xlWorkbook.ActiveSheet
Print "Uruchamianie importu z pliku excel......."
Dim NumberOfRows As Long
NumberOfRows = xlSheet.UsedRange.Rows.Count
count = xlSheet.UsedRange.Rows.Count
Dim RowPointer As Long
Dim i As Integer
Dim view As NotesView
Set view = dbCurr.GetView ( "Procfolder" )
If view Is Nothing Then
	Exit Sub
Call view.Refresh
Dim antwort As Integer
antwort = Msgbox ( "Będziesz importwał " & NumberOfRows & " zapisanych w bazie danych. Kontynuować?" , 4 , "Start import?" )
If antwort <> 6 Then
	Exit Sub
Dim schluessel As String
Dim doc As NotesDocument
Dim summe As Double
For RowPointer = 1 To NumberOfRows
	schluessel = xlSheet.Cells( RowPointer , 1 ).Value
	Set doc = view.GetDocumentByKey ( schluessel , True )
	If doc Is Nothing Then
		Set doc = dbCurr.CreateDocument
		doc.Form = "Proc_form"
		doc.Proc_ID= xlSheet.Cells( RowPointer , 1 ).Value
		doc.Proc_nazw= xlSheet.Cells( RowPointer , 2 ).Value
		doc.Proc_wag= xlSheet.Cells( RowPointer , 3 ).Value
		doc.Proc_ID_zas= xlSheet.Cells( RowPointer , 4 ).Value
		doc.Proc_data_dod= xlSheet.Cells( RowPointer , 5 ).Value
		doc.Proc_data_waz= xlSheet.Cells( RowPointer , 6 ).Value
		doc.Proc_data_przypisanie= xlSheet.Cells( RowPointer , 7 ).Value
		doc.Proc_nazw_zas= xlSheet.Cells( RowPointer , 8 ).Value
		doc.Proc_cel= xlSheet.Cells( RowPointer , 9 ).Value
		doc.Proc_cel_1= xlSheet.Cells( RowPointer , 10 ).Value
		doc.Proc_general_omow= xlSheet.Cells( RowPointer , 11 ).Value
		doc.Proc_general_zakres= xlSheet.Cells( RowPointer , 12 ).Value
		doc.Proc_general_wdroz= xlSheet.Cells( RowPointer , 13 ).Value
		doc.Proc_general_admin= xlSheet.Cells( RowPointer , 14 ).Value
		doc.Proc_general_zarzad= xlSheet.Cells( RowPointer , 15 ).Value
		doc.Proc_general_zalec= xlSheet.Cells( RowPointer , 16 ).Value
		doc.Proc_general_szkol= xlSheet.Cells( RowPointer , 17 ).Value
		doc.Proc_general_kontrola= xlSheet.Cells( RowPointer , 18 ).Value
		doc.Proc_uwagi_ogolne= xlSheet.Cells( RowPointer , 19 ).Value
		counter = counter + 1
		Call doc.Save ( True , True )
	Print RowPointer & " przetwarzanych rekordów, " & counter & " stworzono dokumentów!"
Next
Print "Rozłącznie z excelem..........."
xlWorkbook.Close False '// Close the Excel file without saving (we made no changes)
Excel.Quit '// Close Excel
Set Excel = Nothing '// Free the memory that we'd used
Print " " '// Clear the status line
Msgbox RowPointer & " przetwarzanych rekordów, " & counter & " stworzono dokumentów!"
Call ws.ViewRefresh
Exit Sub
errmsg:
'/Msgbox (xlFilename(0) & "to")
'/Msgbox ( "Błąd importu " & Error & " w lini numer " & Erl )
'/Msgbox "Linie w pliku excel " & RowPointer
'/Print " " '// Clear the status line
Exit Sub
Subject: Problem with import from excel?
-Does the form field: proc_wag after it is imported and before you physically open and re-save it has the correct value? (=“2”)
-What is the field formula? Type? Is it a number or a string?
if it is a string value, then try adding:
doc.Proc_wag= format(xlSheet.Cells( RowPointer , 3 ).Value)
if it is a number value then try cint or clong(xlSheet.Cells( RowPointer , 3 ).Value)
If the value on the form is correct, then before the ws.viewrefresh, add a view.refresh
Hope this helps
