I have a Support call from the client that has an issue with accent in French. the links work fine on the web, but if he put that link on a Link Hotspot I can see the link being good, yet when launched it gives a problem with changing the accents.
Here is an example. http://ABC/ABCintranet.nsf/ContentF/examinateur?open&lang=F&count=10&category=01_Matériels+médicaux@
when I clique this link on the web it works fine but when I clique the hotspot then on the web I get this;
is there a way to keep the link as is from the hotspot so that it does not change the accents when launching the link?
any ideas,
thanks
Alena
