We have a problem with the “Fullname only” setting on our server. If I understand correctly how this is supposed to work, Domino will try to match the exact Internet address of the email to the $Users view. If there is no exact match, it will then check to see if there is an alternate domain name defined in the Global Domain document and try to match against that.
Here is the issue:
We have a user whose email address is janedoe@domain1.com. She is receiving mail addressed to jane_doe.domain2@domain3.co.jp.
Domain3.co.jp is not defined as an alias in our Global Domain document. However, domain3.co.jp is a valid domain name for our parent company in Japan. These emails are coming in to our server from a Domino server at our parent company. Also, Domain2 is the Notes domain specified on the Basics tab of the server document, not the Internet domain name we use for our email.
Also, I have checked the $Users view and nothing even remotely resembling jane_doe.domain1@domain2.co.jp exists.
Subject: Problem with “Fullname only” SMTP setting
sounds like the server where it came in is not set for fullname only, thus jane_doe became Jane Doe and matched so got routed (via notes) to your server. ask them to change their settings.
I have a similar problem, but I had a different understanding of the Fullname only setting. I was under the impression (and I believe I tested this in the past with an older version, but it has been a while) that Fullname only meant match ONLY the full Internet address (not local part ever). If you do Fullname then local part setting, I think it behaves as you described.
But, my problem is that the fullname only setting is matching against local part too, which appears to be a bug to me. There are others that have reported this issue as well, so now I’m off to the fixlist DB to see about pending fixes or recent fixes.
Just a “me too” post, but thought I would share (misery loves company).
Subject: RE: Problem with “Fullname only” SMTP setting
Just FYI;I’ve tested this with v6.0.3 and the problem does not occur, which leads me to believe that this was introduced in the 6.5.x codestream somewhere.
