Problem with ftsearch
I have an application where I have to serch for a field called “CompetenceArea”.In this field I have values like “SB”, “SP”, “ST”, “SAA” and so on. I have about 15 different choices.
When I make a question like
FIELD CompetenceArea=SB it works fine
But when I make a question like this
FIELD CompetenceArea=ST
I get 0 results
Why? is ST a reserved word?
Subject: RE: Problem with ftsearch
What are you expecting FIELD CompetenceArea=ST to find? If you want to find documents that contain the exact “word” ST (and might also include other words), you can just search for “ST”.
Subject: Problem with ftsearch
try to use @contains or @isMember in the formula string…
