I have a notes application that runs in the notes client I have a frameset with 2 frames. In the top frame I have a view with documents listed. In the bottom frame I display a webpage. In the postopen of the selected doc I set an environment variable that contains the URL of the webpage that needs to be opened in the bottom frame. I then do a notesuiworkspace.reloadwindow to load the webpage. Everything worked as expected until I started testing it on different machines.
I run the code on 2 similar workstations but on one the notesuiworkspace.reloadwindow reloads continually.
Specs of both Machines:
OS Windows XP Pro SP2
LN version 7.02 and 7.01 (I tried it on both)
I have tried replacing the webpage with a notes page and it had the same behavior.
I am wondering if there are any settings that might cause this type of behavior.
Please help because, I really don’t know what to do at this point, and I need the application to be able to work.
Thank you.
Beatrice
Technical info:
I have 1 Frameset with 2 Frames, 1 View, 1 Form with 2 text Field, 2 Pages and 1 Environmental Variable
the 2 frames (top and bottom) of my frameset
- "top" frame
- display a named element View "V1"
Default target "bottom" frame
- bottom frame
- display a named element Page value Computed or a webpage :
@If(@Environment("mis-F1") = "Montreal"; "P1";"P2")
Pages
- "P1" only a Blue background
- "P2" only a Purple background
View
- "V1" display only the document of form "F1"
- Target Frame "bottom"
- Postopen:
@Environment("mis-1";"");
@Command([RefreshFrame]; "bottom")
Form:
- "F1" contain 2 fields:
- City (text field)
- Country (text field)
- Postopen:
Dim s As New NotesSession
Dim wk As New NotesUIWorkspace
Dim doc As NotesDocument
Set doc = Source.Document
Call s.SetEnvironmentVar("mis-F1", Cstr(doc.City(0)),False)
Call wk.ReloadWindow
