Problem with forms/document on web
HiWhen a create a new document i use @Command([Compose];“Cont”) my stylesheets and JS works fine but when a edit the created document all stylesheets and JS stop working. I used @Command( [EditDocument]).
What have i missing, i’m not so experienced in web.
Kind regards
Fredrik
Subject: Problem with forms/document on web
Where did you put your stylesheet & JS. i’ve put it in HTML Header Content.
dbname := @WebDbName;
“<script language="JavaScript" type="text/javascript" src="/”+dbname+“/TopNav.js">”
William
