Problem with Find and Replace using word object
I created a word automation object in lotus script, and have some text entered in word. Now i want to find a particular word and replace it with some other word. It works easily in VB but with lotus script i am not able to do the same. Please let me know wht code should i put to get this right.
Subject: Problem with Find and Replace using word object
Folks,
After a lot of trial and error, it was really quite simple.
Dim x As Variant
FindStart:
Set x = objWord.ActiveDocument.Range(0,0)
While x.find.execute(“
x.Text=Chr$(13)
Goto findstart
Wend
Hope this safes others all the effort that I just wasted.
Regards
Stephen
Subject: RE: Problem with Find and Replace using word object
Stephen,Hi, I did try with this, but for me does not works. Could you send me the full code for this ?
My challenge is to create, from a .dot attached in a Notes document, a .doc, but I need to find some words in the .doc document, and then, replace for values of the notes document.
Thanks for your help
Miguel Angel Villafuerte
México
ma@ddinsys.com; miguelangel_villafuerte@yahoo.com
msn: ddinsys@hotmail.com
Here’s what I did: Set selec = worddoc.Range(0,0) 'set the Selection object to start at the beginning of the Word doc
With selec.Find	'find within the selection
	.Text = "<Heading>"	'search for the pre-built flag which determines placement of the introduction
	.Forward = True
	.Format = False
	.MatchCase = False
	.MatchWholeWord = False
	.MatchWildcards = False
	.MatchSoundsLike = False
	.MatchAllWordForms = False
	.Execute
	selec.Text = header
End With
Hope this helps.
Thanks for the code, but it doesnt replace the word though. Is there something else that i need to add to this
It should if the variable “header” (in this case) has a value.
This is what i have coded right now, when i execute this code, it appends “text” at the end of the line, whereas what i need is to replace “test” with “text”.
Please let me knw if anything wrong with this.
Set mydoc = MyApp.documents
Call myDoc.add
myApp.selection.TypeText (“test one test great job if you can do it”)
Set selec = myApp.Selection 'set the Selection object to start at the beginning of the Word doc
Dim header As String
header = “text”
Set selec = myApp.Selection.range
.Text = “test” 'search for the pre-built flag which determines placement of the introduction
.Forward = True
.Format = False
.MatchCase = False
.Execute
selec.Text = header
End With
I wish I could be of more help, but I’m no expert (obviously). My code worked for Word 97, I think. Sorry it’s not working in your case.
