Problem with Export to Excel - Nil Values
I have a user who when he runs a report that exports to excel it does populate the excel sheet but does not enter any values. If I or anyone else runs this report it produces values. Even if I run it as his id it works but as soon as we run it on his computer it doesn’t work. He uses excel 2000 but everything else looks correct. I have tried replacing and re-installing his lotus environment but nothing helps. Has anyone seen this happen before
Thanks in advance for any assistance
Subject: Problem with Export to Excel - Nil Values
What happens when you turn on the debugger at his workstation and run the code?
Subject: RE: Problem with Export to Excel - Nil Values
i have taken over there pc but all looks ok. So strange because I can install their environment and their id on my pc or any other and it works but if they run it on their pc it just produces a blank spreadsheet short of the titles. I have replaced the spreadsheet, the lotus environment and re-installed lotus but still the same result. I belive it is either Excel version or security of excel version.,
Hi,it must be the version problem. i run on the same problem.
after creating the excel object, just give excelobject.visible=true
and run the agent automatically excel sheet open and data will added to excel sheet.
ok, thanks
the excel sheet does open it just has nil values in any of the rows I am calling on dynamically. If I am just adding the date to the date cell its fine - its when I start adding rows and populating them that it just acts like there are no rows to add. Running it anywhere else - even with his id works fine
