Problem with Encryption support in INOTES 6.01!
I installed R6.01 and tried the encryption support new in inotes. It works nicely. You can import your user id into your mail database and read encrypted mail with no issue.
One problem I see though is that you are supposed to be able to delete your user id from your mail database, if you choose to do so after is has been imported. The Delete button is always disabled, even though my id has been imported successfully?
Any one experience this problem??? Any solution?
Subject: *You have to enable this in your configuration document
Subject: Issue Resolved
You are correct. In order to allow users to delete their user id once it has been imported, this option must be setup in the server configuration document, specifically in the “InotesWebAccess” section.
Thanks for the insight!
