Problem with Embedded Object
Hi All,
I am using the following code to embed an object
Set object = rtitem.EmbedObject ( EMBED_OBJECT, “.xls”, “”, “Report” ).
Its throwing an error “Embedded Object class not found in Registry”. Can anyone tell me why this error is being shown.
Thanks in Advance.
Subject: Problem with Embedded Object
Hello from Valencia Madhan,
It seems that the .xls is not a recognised extension…
Try this: Set object = rtitem.EmbedObject (EMBED_OBJECT, “”, “c:\my Reports\Report.xls”)
where the second parameter is empty and the third parameter is the full path yo your report.
Let me know if it works to you. I hope that… :wink:
Josep
Subject: RE: Problem with Embedded Object
I am trying to embed an excel sheet which is not saved in the hard disk…
Then, I will do something like that:
1.-Use a OpenFileDialog to obtain all the path.
2.-Test if it is empty (we nust be sure).
3.-Then embed the object as I tall before using the filenames(0).
filenames = workspace.OpenFileDialog(False, “Selecct an excel document”,“|*.xls|”, “C:\My Documents”)
If Not(Isempty(filenames)) Then
Set object = rtitem.EmbedObject(EMBED_OBJECT, “”,filenames(0))
end if
Try it…
Josep
