Hi
My problem is that when I try to synchronize Address Book with my Pocket PC, i receive this error message : Not enough memory in the device. I can synchronize Calendar, mail, task but not Address Book. Why ?
thanks
Hi
thanks
Subject: Problem with EasySync Pro 4.2.2
Sounds like your problem is exactly what the error is telling you… that you don’t have enough memory in your Pocket PC to store all the items in your mail file. Email takes up a lot of room and unless you absolutely need it I would recommend that you don’t use it or expand the memory in your Pocket PC. I use a Palm and don’t have any problem, but I don’t sync emails either.
