Problem with doclinks
I appending one doclink into 1 richtext field(Computed) and saving the document.After that i again appending another doclink by using some other code from button into same richtext field.when i am opening that document .,first doclink is prompting error “File does not exist”.Second doclink is opening fine.
If i am keeping richtext field as editable rather than computed., it is working fine for both doclinks.But i need to restrict the user to edit that field.I tried with two rich text fields.,same problem is coming.Only the first doclink(first time it is opening fine)is not opening after appending the second doclink.,second one is opening fine
Doclinks can be appended whether by buuton or agent first or viceversa
