I have a problem importing a Date/Time field with DXL.
I’ve modified the Calendar Entry form in the Mail Template and I’ve created a Form with a button to export my design to a DXL file and then import it to another template.
Everything goes fine importing the new design but when I create a new appointment in the target DB, appears a date instead time format in the two time fields.
I’ve found a way to workaround editing the fields in Lotus Designer and then saving the form again.
I hope that this explanation was not confused.
Any idea is appreciated.
Subject: RE: Problem with Date/Time field imported with DXL
Please send me a sample database containing one form with one field of the type that you can’t successfully export and re-import, and a description of how it behaves differently after you import it.
- Andre Guirard, IBM/Lotus Development andre underscore guirard, us.ibm.com
Useful blog: Best Practice Makes Perfect
For faster answers, be C R I S P Y
Andre,Thanks for your quick response.
could you tell me your email address?
I did tell you my email address.
