Problem with creating Replica
Hi all
I have to move users from one server to another.
I use the move “Move to another server” function
The servers are in cluster and I specify that I would like to make a replica on both servers.
But there is only created one on the “primary” server
The clusterreplication workes
There isn’t any signed in the Adminp log showing any attemt to make the replica on the “secondary” server. I can follow the process step by step on the “primary” server
Any ideas
Thanks in advance
Steen
Subject: Problem with creating Replica
I am having the exact same issue! Have you opened an incident with IBM? Or found a resolution?
Subject: RE: Problem with creating Replica
hi KurtNo i haven’t opened any incident with IBM
I am testing the move procees because we have to move 2500 user’s from 17 different servers to 1.(2)
I have decided to use the “decommission server function” to control that the mailbases are on both servers.
In the process I simply create replicas for all my users and those with replicas will fail.
I will try reposting the question to night
