Problem with CopyAllItems
Hello,
I have some LotusScript code that executes in the Postopen event of a new document. Its purpose is to copy into this new document any attachments that are in the document’s parent document. I got the original code from this forum, and it works perfectly when using a 6.5.3 client. Unfortunately 6.5.4 has just been rolled out and the code has ceased to work. What is happening now is that the ‘picture’ for the attachment is in the new document, but when you click on it, the message ‘item not found’ is displayed. I have used the LotusScript debugger and it appears that no items are being copied into doctemp and the HASEMBEDDED flag = False.
The code is listed below:
Sub Postopen(Source As Notesuidocument)
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim doctemp  As NotesDocument
Dim docsource  As NotesDocument
Dim parentUnid As String
'routine to copy file attachments into the current  document from its parent  doc
'only do it if the request document is new
If Not Source.IsNewDoc Then
	Exit Sub
'attach to back-end document and get docid of its parent
Set doc = Source.Document
parentUnid = doc.ParentDocid(0)
'using this docid copy all the items from the parent document to a temporary document
Set docsource = db.GetDocumentByUNID(parentUnid)
Set doctemp = db.CreateDocument
Call docsource.CopyAllItems(doctemp)
'delete all items from this temporary document except any file attachments
Forall item In doctemp.Items
	If Not (Ucase(item.NAME) = "$FILE") Then
		doctemp.RemoveItem(item.NAME)
End Forall
'copy the file attachments to the current document
Call doctemp.CopyAllitems(doc)
I would be grateful for any suggestions people may have or any ideas that might point me in the right direction
Subject: Problem with CopyAllItems
There maybe another approach to your need,
From the Parent/Source document use the NotesEmbedObject class to find any file attachments and only copy that Class to the new document.
I am not sure why you need to create multiple attachments in the database, (which increases in size and duplication), alternatively these attachments can be stored in one place in a one type of form/document that is referenced thru doc links in docs that need the attachment.
Instead of looking for $FILE, look at each field if it is a RTF type and has EmbeddedObject, then do NOT delete else delete.
Subject: RE: Problem with CopyAllItems
Thankyou I will try your suggestion
